" idle speed on my 115hp will not go below 1000 rpm. back off the idle speed adjuster with minimal effect. also made sure that idle stop is rested against engine (tighten throttle cable). however, the prop is off. does it make that much difference with the prop off? thanks
joe, first time i am firing up my johnsons.....
thanks for you help
ghinall "
