Results 1 to 3 of 3
  1. #1
    Default My homemade swimming platform
    I was looking to buy a swimming platform for the back of my Chapparal to make putting my wakeboard on easier as a freind of mine had fallen off her last time we were out. I didnt want to have a normal platform that stuck out from the back of the boat an additional 2 foot cause the marina would charge me extra to moor her. So i decided to extend the seat of the boat by 10" which would give me a nice area totalling about 2 foot but only actually extend the length of the boat by 10".
    Because i own a company that make wooden and wrought iron gates we have loads of Iroko timber off cuts, iroko is a type of Japanese teak so thought this would be perfect for the board.
    1st: I got a large piece of cardboard and made a template of the back of the boat where the board will sit ( i allowed it to be about 10mm narrower as i did not want it to rub against the sides)
    2: i cut 2 x lengths of 4" x 1" iroko the width of my template and then cut the tongue and groove cladding at 650mm enough to cvover the width
    3 On a large bench ( i used a bench with a top made from 8ft x 4ft ply) tack the first cladding board down to the bench to hold it in place, then i pushed all the cladding up against it to make a solid board. Because all the cladding is the same size and i used the corner of the bench to start off from it kept the cladding all quite square.
    4 I then placed the 2 bits of 4" x 1" over the cladding which had poly urathane glue on ( one being about 4" from the front the other being where i wanted to fix it to my seat) I used 30mm stainless steel screws to secure it in place.
    5 Because i didnt want the seat to rock on the boat i put some smaller bearers either side of the 4" x 1"
    6 i then cut the board with a jigsaw to the shape i wanted. I left the front piece straight for a new ladder to fit and put a bit of a curve shape on the rest (just to make it look better)
    7 The board was then routered and sanded down before applying 3 coats of Osmo oil on.
    8 Because i was going to fit an anti slip mat to the board i didnt want to oil all of the front as i wanted to get a good fixing with the glue. (you can see a flash of oil through the middle as i was wanted to have the anti slip mat down in two sections)
    9 Now i had to fix it to the boat. This was quite easy and i used 4 x 100mm stainless steel bolts with penny washed. I drilled 4 x pilot holes through my board and then held it in place on the boat to mark the 4 holes on the boat. I took the board off then carefully drilled the holes through the seat of the boat.
    10 Next bit took 2 people! I wanted the bolts to go through the boat and then through a piece of timber to act like a big clamp and spread the weight over the boat as not to pull through. I used a mate of mine who climbed into the back of the boat and held a piece of timber in place as i drilled through the 4 holes.
    11 I then filled the holes with Sikaflex to create a good seal and we continued to bolt the board into place.
ID:	11859Note we hade counter sunk the timber to allow the penny washed and the nut to be be flush with the top of the board
    12 Once fitted i filled up the 4 holes with sikaflex to add extra protection and cleaned it all off.
    13 Once fitted this felt extremely secure on the boat even when i put weight on the overhang part of the board but for extra peace of mind i fitted 2 x 90 degree brackets from the transom to the board under neath. I dont actually think it is necessary but i wanted to be on the safe side
    14 I bought some anti slip mat and placed it on the board roughly cut to size then used a 40mm L bracket to follow the shape of the board and mark it on the mat.
    15 It was then cut with a sharp stanley knife and stuck to the board.
    16 Once dry i bolted the new foldable ladder on
    Now its ready to use, total cost was 98 for the anti slip mat and 60 for the ladder (the rest i had lying around but i wouldnt imagine the timber costing anymore than 100)
  2. #2
    Join Date
    Aug 2017
    Location
    South Africa
    Posts
    175
    Default Re: My homemade swimming platform
    Nice job! I did something similar to a boat with an outboard that I converted into a wakeboarding boat, also turned out great.
  3. #3
    Brilliant idea!! and thanks for sharing the step-by-step and pictures
Similar Threads
  1. swim platform
    By bcclew in forum Boat Hull, Deck and Transom Repair
    Last Post: 03-23-2015, 08:40 AM
  2. Under platform ladder
    By Floatation Device in forum Mercruiser Sterndrive Forum
    Last Post: 04-12-2014, 09:55 PM
  3. Swimming with the big ones in Costa Rica!
    By GringoJohn in forum Fishing Forum
    Last Post: 01-06-2013, 06:32 AM
  4. force tilt n trim motor ,should it be swimming in oil
    By sadman in forum Chrysler Force Outboard Forum
    Last Post: 01-30-2012, 08:40 AM
  5. Ever Build a Homemade Exhaust Manifold
    By always_looking in forum Miscellaneous marine engine topics
    Last Post: 12-20-2009, 08:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
