Click forPleasurecraft Marine parts and manuals!
Results 1 to 2 of 2
  1. #1
    Default PCM 5.7 Excalibur motor 2006 MB Sport Throttle Issues
    I have a 2006 MB Sport with a PCM 5.7 Excalibur motor it is fuel injected and is having Throttle Issues. Sometimes it will start and run fine then it will cut out and only idle regardless how much throttle you give it. It is not the gas I checked for water in the gas. Sometimes when I start it up it will only idle regardless how much throttle I give it.. Sometimes I can turn it off wait a few seconds then it will start up and run fine for a little while. Please help!
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    6,845
    Default Re: PCM 5.7 Excalibur motor 2006 MB Sport Throttle Issues
    could be the throttle position sensor....a scan tool is the quickest way to 'see' if it responds to the lever....alternatively, you can use a multimeter but its much harder to see intermittents with that approach....
Similar Threads
  1. Sport Jet 90HP 1994 swap to a newer motor?
    By nfaust01 in forum Mercury Mariner Outboard Forum
    Last Post: 07-21-2017, 06:40 PM
  2. 2004 Nautique 196 PCM Excalibur 330
    By Buddy2300 in forum Pleasurecraft Marine PCM Forum
    Last Post: 10-07-2014, 11:29 PM
  3. Sport jet 450 motor help
    By ddaug in forum Other Outboard Motors
    Last Post: 06-17-2009, 05:58 PM
  4. 2006 Sea Ray Sport Trim Issue
    By Brad Walters in forum Mercruiser Sterndrive Archive
    Last Post: 07-21-2008, 04:29 PM
  5. Busted Mercury Sport Jet 175 XR inboard Motor
    By Tara Lachinski in forum Mercury Mariner Outboard Archive
    Last Post: 04-26-2008, 01:59 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
