Hello, I'm looking for some ideas on my BF115.
I've had it for 2 yrs. looking back it has seemed to be making an air bubble sound that has gotten worse over time. The last time out it was stalling on the lift procedure and then seemed weak. I looked up bleeding and adding fluid and got some TnT fluid to add.
1. I raised the motor using power and then took off resevoir cap. It took 3-4 oz. then hit level. I slowly released the manual screw to let it down slowly and a cup of chocolate milk came out slowly. (was I supposed to have the cap off while lowering or on?)
2. After seeing how much came out and its color I read that this indicates water in the fluid and read that some folks siphon out the chocolate milk using an oil sucker. I asked the honda mech. who didn't have a solid background but he said he's done the bleeding procedure and used it to burp out the milky fluid on purpose to purge it out of the system. He said he always leaves the cap on when he bleeds mercs.
After losing the initial cup of fluid the motor would reluctantly raise 2-3" then the trim motor would just whir. I repeated the adding of fluid, raising it with a cherry picker and letting it sit at least 10 minutes between. It took fluid each time but after adding several times the motor still won't raise very much 2" then quits.
Can I get rid of the milky fluid somehow that is stored in the rams without taking the unit off of the boat?
What's my next step? I had no visible leak around the seals.
Will my TnT ever function again? Getting worried here!
Thanks,
Esox
Thanks,
Esox
