1987 Johnson 275 hp
stagehand415
Were is the electric fuel primer pump located and why should you not use a pump ball. Thank you in advance for any help, Also I do have a factory manual and still can not locate the fuel pump.
Start at your fuel tank outlet and follow the fuel line all the way to the motor. If it's got one you should find it. The reason they use it, it takes forever to use the manual primer bulb but you can use one if it's got the proper I D fuel line.
