Click forPleasurecraft Marine parts and manuals!
Results 1 to 5 of 5
  1. #1
    Default PMC 351 (Ford) circa 1990 - Electrical issue
    I have a 1990 PCM Ford 351 in a Supra Conbrio.
    I tried to use a mini portable jump starter to start it, and it shorted "something" out. Now, any time power is connected (i.e. battery hooked up) the starter engages, even if key is not in the ignition.
    Which part(s) did I possibly short out?
  2. #2
    Default Re: PMC 351 (Ford) circa 1990 - Electrical issue
    Answer: starter solenoid
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,172
    shouldn't have...more likely the main fuse at that solenoid...
  4. #4
    You would think... but the breaker was not even tripped. The solenoid was shorted out.
  5. #5
    I would test/check the 50 Amp circuit breaker.
    My 50 Amp circuit breaker on rear of engine where starter relay is also located failed over time, could not figure out until it failed. Replaced a batter I did not need to, check cleaned all connections at all locations. R & R Mando alternator twice to have tested (its good) (Dash VM was barely 12Volts, add acc. it dropped.
    Circuit breaker never tripped off, but was preventing full voltage from being passed through to rest of system. No volts no start. Ohms meter confirmed there was not continuity. Dealer wants $108, I bought on amazon.com for $38 prime, ebay was $35 free shipping.
    I used a $5 50 amp auto parts store circuit breaker as a fix until the Blue Sea Systems part #2142 shows up from amazon.
    Dash Volt meter went right back to showing 13-14 volts after replacing the circuit breaker.
Similar Threads
  1. 1992 OMC Ford 5.0 Maj. Electrical malfunction
    By mashed_finger in forum OMC Sterndrive and Inboard Forum
    Last Post: 08-06-2015, 12:13 AM
  2. Electrical issue
    By island_boy in forum OMC Sterndrive and Inboard Forum
    Last Post: 05-16-2012, 06:11 AM
  3. FORCE 5hp circa 1990's
    By Jackman1939 in forum Chrysler Force Outboard Forum
    Last Post: 12-07-2011, 11:40 AM
  4. Temp amp Electrical Issues 88 Bayliner 23 l Ford OMC
    By morgie in forum OMC Sterndrive and Inboard Forum
    Last Post: 11-17-2009, 08:48 PM
  5. Electrical Issue
    By dskwarok in forum Johnson Evinrude Outboard Archive
    Last Post: 10-24-2008, 11:46 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
