James Anfossi
Hi Guys,
I have been having some ignition issues. My motor runs for around 40minutes and then the coil starts breaking down, I am not sure if the coil is actually the right one so I have a new mercury sierra one on order. I figured its either the coil breaking down or its getting too much voltage. I measured the voltage to the coil when its running and when I rev the motor it gets above 11volts and it is my understanding it is suppose to be 7-10v supplied to the coil. I also have noticed when cranking I cant seem to measure the 12v from the starter motor, I see about 4v - but it starts right up after 1 or 2 cranks.
I did order a new resistance wire and put that on and it still gives above 11v. I then attached the two resistance wires together (the old and new) and now it gets just a hair above 10v when i really rev it.
Why am I getting excess voltage with my resistance wire?
Why does it seem to give me what I need with two resistance wires attached?
I do have a "ONE WIRE Delco Marine Alternator Mercruiser Volvo 100A" from ebay, paid about 75$ for it.
Thanks a lot
Thanks a lot
