Results 1 to 2 of 2
  1. #1
    Default 1969 Ford 302 Interceptor Plug Wire Location
    Have a 1969 30' Trojan with twin Ford 302 Interceptors. Ordered and received new distributor caps and the plug wire numbers on the top of the cap are different from the diagram and placement we've been using for years. Can anyone confirm the correct plug wire location for me? It's the Mallory flat cap.
    Thanks!
  2. #2
    Join Date
    Mar 2009
    Location
    Portland, Oregon,
    Posts
    9,800
    Default Re: 1969 Ford 302 Interceptor Plug Wire Location
    I'm not sure about the Interceptor engines... but in the Windsor family, the 5.0L and 5.8L do not share the same firing order.
    (just an FYI on that)
    Your ignition distributor cap will be indexed to the distributor housing..... so in essense, you are locked into this if the cap towers are numbered, and if you wish to use their numbering system.
    The distributor housing indexing can be placed where you want it to be, as long as the cap towers correspond correctly to each cylinder as per the firing order.
    This may mean lifting the distributor, and re-indexing it.
    If so.... be sure to re-set the ignition advance.
    And since this is an older Mallory unit using the flat cap, be sure to examine the flyweight system.
    These are years old by now, and if water or moisture caused any damage, the flyweight return spring values may have become compromised by now.
    Rusty and weak return springs can lead to premature progressive advance, and will cause engine damage.
    Rick ... aka Ricardo..... AQ series Volvo Penta repair
    Portland, Oregon
    28' SDN F/B w/ twin Volvo Penta 5.7L DP's
    Please... no PMs! Post your questions on the forum.
Similar Threads
  1. 1969 Ford Interceptor Need to Identify Motor & Eaton outdrive ?
    By 1pacosbill in forum Ford Interceptor Marine Engine Forum
    Last Post: 02-01-2011, 01:31 PM
  2. 390 Ford Interceptor
    By Dave Sarlund in forum Ford Interceptor Marine Engine Forum
    Last Post: 10-27-2006, 03:39 PM
  3. Ford Interceptor
    By Ron Grabloski in forum Ford Interceptor Marine Engine Forum
    Last Post: 08-24-2006, 03:26 PM
  4. Ford Interceptor
    Last Post: 08-13-2002, 08:33 PM
  5. b57 Ford Interceptor
    By sampolito in forum Archive 2002-2006
    Last Post: 11-18-2000, 10:33 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
