Hey all, I recently got a 1986 mercury 50hp when I bought a pontoon project. I went to try and start the motor and when I turn the key the start will engage, then turn the fly wheel maybe once then whine as if it is starving for power. I am using a fully charged cranking battery with more than enough power to crank the engine and even tried to jump the thing but am still getting the same result. I pulled the plugs out and turned the key to check the starter and the thing spun the fly wheel around no problem. Any ideas what could be going on? Im relatively new to marine engines so any advice would be much appreciated.
