Glen Miles
Hi,
I bought a Prosports with a 2000 BF130 last year. The boat ran fine last season.
Since I commissioned the boat for this season, my BF130 occasionally splutters when in gear and will not increase revs until mostly either I shift back to neutral a few times and/or turn it off and restart, although sometimes it comes good by itself.
Occasionally when I hit a wave, the revs drop right off, but then come straight back.
Last weekend when towing a tube, I couldn't get past 13kts at 4000rpm - it will normally sit at about 20kts at 4000rpm.
It smells like its running rich.
I filled the tank and added stabiliser for the winter.
Ive changed plugs to the good NGKs.
Changed the external fuel water separator.
Changed the LP fuel filter (first one inside the engine cowling)
Today I added Startron to the tank, changed the high pressure filter, emptied the onboard separator, changed the inline filter (the vertical one aft of the VST.
When I changed the high pressure filter (part 16911-ZY3-010) the one that was in there was bent in the middle - not sure what happened there!
Not sure where to go from here. When it runs, it generally runs great - I get 30kts out of it with my Prosports 2200WA. It starts first go every time without priming the bulb, there are no spluttering issues in neutral - if it is spluttering I can put it in neutral and it revs smoothly), and it idles fine.
Thanks,
Glen
Thanks,
Glen
