PCM transmission oil...
lpjjrose
How can I tell is my PCM transmission has 20-20w or Dextron III? It appears to be a bit red. I would guess 20-20 is more clear?
A red/pink tint is indicative of transmission fluid use.....another way to assess the fluid is to put a drop or two onto a paper towel....and then compare it to samples of either fluid from a can...finally, you can also put a drop between you finger and thumb and then separate the two...the trans fluid is usually much "thinner" due to its lower viscosity...
