Grumpy Bear
Thanks ahead of time! Couple of short video clips to watch/listen to if you can. Motor is "warm" and warm-up throttle is all the way down. Choke is off.
So, I have:
- Link & synced (3 times to make sure)
- Turned out the carb idle screws about 1.25 turns or so (I've tried 1.5 and the result is basically the same)
- Checked compression, and it's perfect
- Made sure every plug wire is getting consistent spark and tested every spark plug
But it still runs at high idle and pretty rough as you can see. If I put her in gear (which I really shouldn't do at 1200 RPMs) she still hesitates and dies. What do I adjust next?
Thank you!
So, I have:
Thank you!
