Curmudgeon
Can the exterior transom shield in said application be removed without pulling the engine?
VP schematics for the single PDS show the bearing to be 3851019, was 11013, hence the conundrum. In your considered opinion, what's the highest quality sealed bearing available ...
The VP pn 3851019 is an industry standard bearing.
And it's also an 'open' bearing. I guess my frustration is ordering parts from the Volvo schematics, and they aren't the correct part.
Are you using an OEM service or work shop manual???? Or Seloc or Clymers????
What the heck did folk do before the internet! I understand 62062RS is the closed version (thanks for that) and have one on order, just don't understand why there's no closed bearing listed by VP (that I can find) ...
The 6206 designates the bearing.
The 2RS designates "sealed" bearing.
You can take a 62062RS and pick the seals from it and have a 6206...... but not the other way around.
Trust me...... with the C drive and single bearing PDS, (unless you were to create grease porting to the Bearing Box area..... of which can be done), you need a sealed 62062RS.
If interested in grease porting the BB, I can send you my instructions! (you will not find anything on this via Volvo Penta, by the way)
