Results 1 to 2 of 2
  1. #1
    Default 21" 3-blade to 23" 4-blade?
    Johnson 70hp VRO has now 13x21 Solas Amita 3 aluminum prop.
    Boat is Argo 17 race boat, this combination is capable to +/-50kn. (with cleaver etc.)
    Solas says that this prop has wide blade design ment especially for 4-stroke engines.
    Johnson revs 5600 wot and takes 39kn, with wife an kid in boat.
    Now, considering more top speed, I have an opportunity to buy a 13.25x23",OMC Renegade for reasonable good price. However 4th blade and 2" gain in pitch makes me wonder... Is it too much?
    I have a jack plate and there's fairly much to lift engine more. I think Renegade would work much better lifted than Amita.
    But how this "wide blade design" alu compares to 4-blade steel?
    Is it worth to try or do I see revs drop under 5000?
    Opinions are welcome.
  2. #2
    Default Re: 21" 3-blade to 23" 4-blade?
    Thanks.
    I'm aware that ~200rpm drop per inch, but what I'm not aware that how affects one more blade? Will it drop more or not? And my motors rpm range @wot is 5000-6000.
Similar Threads
  1. 3 blade 11"&13" props for older mercurys
    By paul1972 in forum Propeller Selection and Replacement
    Last Post: 04-29-2014, 05:42 PM
  2. Design Feature "V" - "Special Gearcase" - What does this mean? J150VXSIG
    By weirdaljr in forum Johnson Evinrude Outboard Forum
    Last Post: 05-14-2011, 08:59 AM
  3. Replies: 3
    Last Post: 02-22-2011, 11:31 AM
  4. Replies: 4
    Last Post: 01-19-2011, 03:28 PM
  5. Props 3 blade vs 4 blade stainless vs alum
    By dbiele in forum OMC Sterndrive and Inboard Archive
    Last Post: 07-02-2007, 06:58 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
