Joe Baublis
I removed the gear box to replace the water pump. I had removed the shift link, wrongfully thinking that it's detachment would help remove the gear box. I removed the gear box with the link detached. I replaced the water pump, and re-installed the gear box. As a test, I turned the flywheel clockwise, and I found that the propeller rotates forward only - even when the shift level is in reverse. So I pulled out the gear box, and re-connected the shift link, and re-installed the gear box. The propeller still turns forward whether the shift mechanism is in neutral or reverse or forward.
Is there a cure for this problem?
