zaschf
Hi all,
since last month's fixed electrical issues with the old engine all when fine, so I thought.
But it idles rough and will stall when put in gear and I can't get the engine to idle at the recommended rpm(650). It won't idle below 1000rpm.
The obvious suspects are the carbs so taken them off the engine and cleaned and checked the thoroughly. They were actually clean as a whistle and no wear marks.
Next were the spark plugs which I had replaced during my electrical fault finding. Guess what? Look at the attached photo and you'll see that they are old spark plugs. The new ones are still on the bench which I forgot to put in. Case of a senior moment.
Then I noticed something odd with the spark plugs. Number three is fairly clean and with some rust marks on it. It there water getting into number three?
And out came the compression tester and I got the following readings:
1 - 122
2 - 126
3 - 106
4 - 130
Also when I took the carbs off, water was falling out of the inlets!! I guess, that shouldn't happen.
Okay, what's the general consensus here. A complete engine overhaul or something less drastic?
Cheers,
Frits.
1 - 122
2 - 126
3 - 106
4 - 130
Cheers,
Frits.
