Results 1 to 6 of 6
Thread: trailer rating
  1. #1
    Default trailer rating
    Is there a general rule of thumb for how much extra rating is safe ? My boat is 4800 lbs is a 6 k trailer good ?
  2. #2
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,653
    Default Re: trailer rating
    That should be no problem at all. A large margin of error is not necessary because normally the maximum rating on a trailer takes into account all kinds of variations. If the rating plate says 6,000 lbs. then it will safely carry 6,000 lbs. assuming tires and springs are in good repair.
    You need to be most mindful of the tires. Make sure the combined maximum rating of the tires exceeds the gross weight that you are trailering (boat and trailer) by 20%.
    CHawk 25 DLX
  3. #3
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    8,000
    Like chawk said, if its rated for xxx lbs, it will carry it. Just make sure the 'boat weight' is accurate. most of the OEM data is 'empty' and adding gear and fuel will increase it rapidly, especially as the boat size grows...
    And 2x on getting good tires for the trailer. Ideally, go for a commercial rated tire (higher ply count) - they will last much longer and are much more durable.
    Finally, ensure the boat is loaded on the trailer correctly - so the tongue rate is correct, and you should be good to go.
  4. #4
    Thanks for the replys
  5. #5
    Join Date
    Mar 2007
    Location
    Miami Lakes, Fl, USA
    Posts
    113
    Also review the requirements of your State for brakes on trailers and make sure you are in compliance.
  6. #6
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    3,143
    Make sure you empty all of those beer coolers onboard! Ha Ha
Similar Threads
  1. 4.3LX HP Rating
    By motogotro in forum Mercruiser Sterndrive Forum
    Last Post: 07-27-2010, 06:36 PM
  2. 37L power rating
    By atilla_boy in forum Mercruiser Sterndrive Archive
    Last Post: 08-15-2008, 04:35 PM
  3. HP rating
    By saved in forum Nissan Tohatsu Outboard Archive
    Last Post: 03-18-2008, 08:42 PM
  4. Hp rating
    By 71gullwing in forum Chris Craft Engine Forum
    Last Post: 05-29-2007, 09:11 PM
  5. HP Rating
    By W. SAdler in forum OMC Sterndrive and Inboard Archive
    Last Post: 08-26-2006, 12:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
