Results 1 to 2 of 2
  1. #1
    Default preferred brand of 2 cycle oil??????
    I use Valvoline TCW3 spec. I was given a gallon of Havoline TCW3 spec. any body have information regarding either as better???? thanks
  2. #2
    Join Date
    May 2011
    Location
    slough ,berkshire uk
    Posts
    161
    Default Re: preferred brand of 2 cycle oil??????
    if both are tcw3 , then that is what they are supposed to be, but only meet minimal standards !!!
    personally would NOT use either one.
    Texaco oil in general is crap unless you buy heir most expensive.
    Just taka sniff and if you can smell a fishy sort of smell then its reconstituted ****.
    I had a car years ago that had fantastic oil pressure until I put in Texaco Valvoline I it, siezed the engine.
    both vavoline and havoline are texco crap. Both the same oil............
    buy either BRP OR MERCURY AND STAY SAFE both have superior additives for outboard engines.
Similar Threads
  1. Accidentally put 2 cycle oil in 4 cycle motor oil tank
    By sharonmc2011 in forum Mercury Mariner Outboard Forum
    Last Post: 09-30-2013, 07:14 AM
  2. Is the brand name for 2-cycle oil important ?
    By cocomo in forum Fuel Gas Oil Mixture Ratio
    Last Post: 06-15-2013, 08:03 AM
  3. Brand new 3.0 overheat
    By captnbill in forum Mercruiser Sterndrive Forum
    Last Post: 05-02-2010, 09:35 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
