I have a 1994 Merc 2 stroke, 4 cylinder. Every once and a while when I am at full throttle it feels as if it is starving for fuel. If I leave it at full throttle it will lose RPM until it stalls. It does not chug or sputter, it simply looses RPM. If I throttle back to 1/4 throttle or so it will continue to run. I let it stall the other day, I went back and pumped the primer ball and It started rite up just like it has when this happened in the past. Then I was able to run full throttle back to the dock (10 minutes or so full throttle) no problem.
I have done mechanical work all of my life so I know my way around most anything mechanical. This past spring I rebuilt the carburetors and fuel pump and went to Florida. It ran perfect for 14 days and then one day I am motoring back to the dock and I experienced this problem for the first time. It started back up and I went to the dock. I looked at everything and decided to replace the primer bulb and fuel lines just encase. I go out every day for 4 more days and then it does it again.
So today I drain and pull the tank to see if there is something in the pickup. The tanks is clean with nothing in the lines. It all looks just fine.
I am going to take the carburetors and fuel pump back off and go through them.
What do you think about this? Thanks for any input JC
