solarflare
Hello everyone,
I recently purchased a 90HP engine that has less than 100 hours on it, but the #2 piston had a head gasket blow, and subsequently the top ring got sheared in the exhaust port, then the engine sat in storage (on the original boat) since 1997 (18 years).
Instead of doing a full teardown on what is essentially a new engine, I decided to go in through the reed-valve openings and pull the piston out that way. All has gone well so far except...
When I tried torquing the connecting rod cap bolts, after the initial torque (15 in-lbs) and alignment check, I can't seem to achieve final torque (30 ft-lbs or 360 in-lbs) and the bolt seems to be easier to turn. I also did not get the socket all the way on the other bolt as I was torquing it and partially stripped the head.
In all my other engine work (which is not tons), I have never run into stretch-bolts as far as I remember.
My questions are:
- is 30 ft-lbs the correct torque for this engine? (serial 0E019700)
- is 360 in-lbs the same as 30 ft-lbs?
- are there more specific steps in torquing the connecting rod cap bolts?
My confidence is waning,
- Jeremy
My questions are:
- Jeremy
