Results 1 to 6 of 6
  1. #1
    Default HELP!!!!!1987 omc 4.3
    Hello new to the forum. I have 1987 gm 4.3 omc engine. I need a engine rebuild kit but don't know exactly which one to get if someone could please help me thank you very much
  2. #2
    Join Date
    Sep 2008
    Location
    Maryland - USA
    Posts
    7,178
    Default Re: HELP!!!!!1987 omc 4.3
    welcome to ME.com!!
    First off, you'd been better off posting in the OMC section for OMC questions.....
    To address your question, I'd suggest just taking the block to the machine shop that's going to do that work and let them give you recommendations on parts if you want to buy them separately....usually, is more time & cost effective to let them assemble the whole thing...usually benefits the warranty concern, too. Only caveat is make sure they know this is a boat engine and they know what it means.
    BTW, unless the block in question was fresh water cooled, I wouldn't waste any time or money in it...
  3. #3
    Quote Originally Posted by makomark View Post
    welcome to ME.com!!
    Thank you you very much for your response. I didn't know there was such a thing my bad. I plan on doing the job myself I just didn't want to buy the wrong parts online. IDE rather buy them all at once like an engine rebuild kit that comes with rod and bearings crank and pistons and what not. And yes it is fresh water cooled.
  4. #4
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,472
    Ayuh,.... The motor has to be torn down, evaluated, 'n Then sizes of parts are determined, 'n the machine work necessary,....
    Maybe you oughta be lookin' at crate motors,.... a full on rebuild might be more involved than ya think,....
  5. #5
    The thing is I'm replacing a faulty head gasket and since I'm in the engine I want to basically overhaul it. If it comes down to me having to get it machined than so be it but I need at least the proper gasket kit
  6. #6
    Join Date
    Dec 2006
    Location
    Posts
    5,472
    Quote Originally Posted by Nwoodruff View Post
    Ayuh,.... Point is, until the motor is disassembled, cleaned, measured,'n evaluated,....
    Ya don't know what parts ya need,.....
Similar Threads
  1. need help 1987 190
    By Ron Anthony in forum OMC Sterndrive and Inboard Forum
    Last Post: 04-29-2011, 06:59 PM
  2. 1987 omc 3.0 L
    By widi59 in forum OMC Sterndrive and Inboard Forum
    Last Post: 01-29-2011, 11:27 AM
  3. 1987 4.3L help
    By bunger79 in forum Mercruiser Sterndrive Forum
    Last Post: 05-16-2010, 06:31 PM
  4. little help 1987 30 hp
    By HANBACK in forum Mercury Mariner Outboard Forum
    Last Post: 04-15-2010, 12:21 AM
  5. 1987 25 hp need oil gas mix deb
    By debby in forum Archive 2003-2009
    Last Post: 04-15-2004, 08:30 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
