Results 1 to 2 of 2
  1. #1
    Default Reed valve replacement on Johnson 70 hp 1982
    Hi to those on forum. I have a 1982 johnson 70 hp model#J70ELCNB. I'm trying to replace the reed valves because there is no low end torque. They list them as unavailable in the parts breakdown. Will 2001 reed valve sets work in this motor if they are bought for 70 hp motor? If anyone knows if there is an interchange for them. Thanks Hutch1955
  2. #2
    Join Date
    Sep 2010
    Location
    ontario
    Posts
    13,944
    Default Re: Reed valve replacement on Johnson 70 hp 1982
    The reed valves are very reliable.-----Rarely need to be changed !------------Do you have the correct prop on this motor that suits the boat and what you do with it ?----------Have you done a compression test ?---------Have you checked for spark on all plug leads ?------Doubt that new reeds will solve your problems.
Similar Threads
  1. 2000 115 reed valve replacement
    By Skimmons in forum Mercury Mariner Outboard Forum
    Last Post: 04-24-2014, 07:20 AM
  2. Reed valve?
    By Nancy Knoblauch in forum Mercury Mariner Outboard Forum
    Last Post: 09-19-2011, 09:49 AM
  3. jOHNSON 130, bad reed valve?
    By henry10ban in forum Johnson Evinrude Outboard Forum
    Last Post: 01-28-2011, 04:51 PM
  4. Reed Valves for 1982 75hp Johnson
    By mike77cj in forum Johnson Evinrude Outboard Forum
    Last Post: 04-06-2010, 09:33 PM
  5. 99 omc reed valve
    By d.shaw in forum Johnson Evinrude Outboard Archive
    Last Post: 03-17-2004, 01:14 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
