Results 1 to 3 of 3
Thread: synthetic
  1. #1
    Default synthetic
    can a two stroke 50:1 mix change to a synthetic mix two stroke will it hurt to use one tank and go back to
    regular twc3
  2. #2
    Default Re: synthetic
    As long as it's pre-mixed, it doesn't matter. If you have oil injection, occasionally mixing older TWC3 oils with newer synthetic blends, the oils will not blend, and will sometimes cause gelling in the oil tank. As a personal observation- Shell V_power premium gasolines have been known not to pre-mix well with synthetics, and can cause the detergent agents in the gasoline to separate. The detergents separate and lay in the bottom of the fuel tank, looking like grenadine.
  3. #3
    Join Date
    May 2016
    The land down under
    I had the self oiling system on my 135 blackmax removed and changed over to Amsoil Saber 100:1 pre-mix with no problems, engine runs cleaner with heaps less smoke.
Similar Threads
  1. Synthetic oil ???
    By Titewad in forum Suzuki Outboard Forum
    Last Post: 08-05-2011, 04:27 AM
  2. synthetic oil?
    By scott_duerring in forum Crusader Marine Engine Forum
    Last Post: 08-23-2010, 04:06 PM
  3. Using Synthetic oil in 496 Mag
    By camaco in forum Mercruiser Sterndrive Forum
    Last Post: 01-18-2010, 10:48 AM
  4. Synthetic Oil
    By lucky_bum in forum Nissan Tohatsu Outboard Archive
    Last Post: 03-05-2008, 08:06 PM
  5. Synthetic oil
    By JS in forum Archive 2002-2006
    Last Post: 09-21-2001, 11:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
