You have power steering. When the power is off, you still have steering, albeit stiff steering ...
With the C drive, I'm thinking that he should not have all that much resistance while the engine is not running.
He would feel the resistance of the cable operating the slave valve, and then the resistance of the hydraulic fluid that's being pushed out of one end or the other of the cylinder..... the rest should be easy.
Ricardo it is a sp-c1 duoprop outdrive. it is a 1995 carver 250 express(looks like a Searay). I was just wondering if there was anything else to disconnect on that model of steering?
Curmudgeon is it normal to be very stiff with the engine off?
i believe my steering cylinder is Volvo penta 872215.
Your drive would actually be a DP-C1....... and being a DP-C1 puts it into the AQ series.
The AQ series collar steering fork bushings can cause stiff drive articulation.... but with Power Assist, you may not feel it at the helm wheel while the system is active (engine running).
I think what Rick is saying does the drive steer easy with the power steering disconnected from the steering arm?
Yes.... and precisely the collar steer fork bushings.
The grease port for these bushings brings grease into the shaft OD and bushing ID area only..... but if water (worse yet salt water) has gotten between the bushings and the aluminum bushing bosses, the corrosion expands as such strength, that it will cause the bushings to squeeze down on the collar steering fork shaft with enough force to cause stiff steering.
This is why I suggested to disconnect all linkage from the spindle arm, and see how well the drive turns to Port/Stbd.
I've repaired these over the years with this very same issue.
One twin engine boat's bushings/forks were so bound up that we had to place wedges between the fork "U" and transom shield, and then litterally drive down on the fork shafts (large aluminum punch and large hammer) to remove them.
For a while, I did not believe that they would come out!
Once the aluminum bushing bores and fork shafts were cleaned up, and once the new bushings were installed, a baby could move the drive Port/Stbd easily.
