Results 1 to 2 of 2
Thread: 5.7 steaming
    Sep 2009
    157
    Default 5.7 steaming
    new barr manifolds and risers last year running 3000rpms i see what apears to be steam.engines are half system engines run at normal temp.no matter what what rpms.at lower rpms very little steam. i remember some merc 5 7 useing a restrictor gasket .p am wondering if the water is getting out to fast not staying long enough? i took the old mans and risers off together so i dont know what gasket was under the riser.next trip i am going to run yhe heat gun on the mans and ck it risers rub like 96 to 105 was heat spec i was told.qhat should the mans be? mabe i am looking at this all wrong? thanks for any help
    Dec 2006
    Chaumont Bay, N.y., USA
    5,469
    Default Re: 5.7 steaming
    Ayuh,.... Just the action of a runnin' a boat motor at 3000 rpms, is throwin' massive amounts of water into a flamin' 1,000 stream of exhaust gases,....
    Add local weather conditions, 'n seein' steam, Ain't all that outa the ordinary,....
  1. steaming 318 inboard
    By nauti-gal in forum Other Gas Inboard Mfgs IO and Sterndrive Questions
    Last Post: 08-07-2014, 09:21 PM
  2. Crusader 350 steaming issue
    By foxsurf in forum Crusader Marine Engine Forum
    Last Post: 01-17-2012, 10:05 AM
  3. Excessive steaming
    By tjgimp in forum Mercruiser Sterndrive Archive
    Last Post: 06-06-2009, 10:25 AM
  4. Steaming Exhaust 454 Crusaders
    By donnyb in forum Crusader Marine Archive
    Last Post: 05-08-2007, 01:15 AM
  5. Steaming exhaust
    By Ray Daoust in forum Archive 2002-2006
    Last Post: 03-06-2006, 01:59 PM
