Hey guys.
My 1996 Johnson 8hp motor was acting odd (felt like no power when going forward).
I talked with some people who suggested it may be the coil pack. Kepp in mind - the engine was starting up - just felt like no power.
I replaced the coil pack with an authentic johnson part (matched part numbers too!).
Now the engine simply doesn't start!
I checked that the wires were pressed all the way down on both the coil pack and the spark plugs.
These are NEW plugs that work.
So I tested the compression - solid 110 110 - so THAT is good news (unless it's supposed to be higher heh).
Anything else tp check for? Could I just have a bad coil pack? I had to order this one - and wait for shipping - so I would rather not return it until I can know if it is bad or not.
PS - I do not have a spark tester - are they cheap?
