fisherman421
I'm new to the forum but have read several posts in the past and successfully used some of the advise given. Thanks in advance.
I purchased a used Sea Hunt 186 with a Yamaha 115 2 stroke both 2003 at the end of last year and launched on Saturday Jun 6 2015, with fresh high test gas. Motor runs fine above 1500 RPM but stalls below 1200 and will not come to idle. Starting it at high rev then putting into gear the motor stalls. We got in ok but was a little nerve wracking. Also burned 10 gallons in about an hours and a half cruising at around 1500 to 2000 RPS inside water way. Basically going slow not on plane. Water separator filter has been replaced, fuel filter emptied and screen cleaned, new plugs gaped at .039. Going to look at the idle mix adjustments 5/8s. Any and all comments would greatly be appreciated.
