Results 1 to 2 of 2
  1. #1
    Default 3208 rocker assembly
    Looking for instructions to remove the rocker assembly and assemble back. going to replace the injectors. any help would be great. also torque specs for bolts and injectors.
    thanks
  2. #2
    Join Date
    Sep 2015
    Location
    CA
    Posts
    74
    Default Re: 3208 rocker assembly
    If I'm not mistaken, remove the valve cover and the rocker arm assembly, disconnect the fuel line that connects to the injector. You're gonna have to push the head adapter to get the injector out.
    Hopefully this helps
Similar Threads
  1. Rocker Arm Assembly
    By Trojanman in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 12-22-2011, 08:14 AM
  2. 440 Rocker arm Adjustment
    By capt_chad in forum Chrysler Inboard and Sterndrive Forum
    Last Post: 12-29-2010, 06:51 AM
  3. OMC 30 rocker arms
    By widi59 in forum OMC Sterndrive and Inboard Archive
    Last Post: 12-14-2008, 11:22 AM
  4. Rocker arm adjustment
    By Dean Jeffery in forum Volvo Penta Gas Archive
    Last Post: 07-15-2007, 06:14 PM
  5. Rocker Arm specs
    By macozo in forum Volvo Penta Gas Archive
    Last Post: 09-02-2006, 07:53 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
