decker5484
Hello all,
I purchased a used upper unit for my OMC outdrive. When it came in, I went to install it and its not mounting correctly. I located the problem which is the anode on the front of the lower unit. The new upper unit has a big flange where the anode sits on the lower unit preventing it from seating all the way down. I looked at the old upper unit which does not have this flange allowing room for the anode on the lower unit. It also looks a bit different where the trim cylinders bolt up.
My question is will this unit still work on my lower unit? Is there a different anode I need to make the upper and lower bolt together correctly? It will seat all the way down as long as the anode is taken off. Any ideas? Thanks in advance.
Matt
Matt
