Results 1 to 2 of 2
  1. #1
    Default need help with seting the float
    I need help on where te float should be set on my carb it's a Montgomery word motor madein 73 it's a 7hp any help would be great thanks for your time
  2. #2
    Join Date
    Aug 2014
    Sydney, Australia
    Default Re: need help with seting the float
    Is the float height adjustable? Often you can only measure it and then replace the needle and seat if it is out of specification. I'm not sure where you would find the specification to measure it though. Are there any PDF service manuals around on the net?
    Subscribe for boating and mechanical videos at http://YouTube.com/DangarMarine
Similar Threads
  1. 4HP Float hieght
    By [email protected] in forum Mercury Mariner Outboard Forum
    Last Post: 04-11-2014, 07:28 AM
  2. Float too big?
    By flyfishn in forum Johnson Evinrude Outboard Forum
    Last Post: 08-06-2012, 09:52 PM
  3. Float losing buoyancy What would be the symptoms of a bad carb float
    By tcarpe1 in forum Johnson Evinrude Outboard Archive
    Last Post: 04-21-2009, 11:46 AM
  4. Float Level or Float Drop
    By maxtor in forum Mercruiser Sterndrive Archive
    Last Post: 07-16-2007, 08:04 PM
  5. Points gap seting for a 43 v8 omc
    By stevemizrahi in forum OMC Sterndrive and Inboard Archive
    Last Post: 03-08-2007, 09:09 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
