Results 1 to 8 of 8
    Default Water heater -heat exchanger
    I am about to replace my leaking 6 gal water heater that, although is equipped to do so, the heat exchanger is not connected to the motor to heat water while underway.
    Engine is raw sea water cooled rather than a closed system. Can I use the raw sea water or is it ill advised? If I can, any recomendation where I can get information such as where best to tap into the engine to pick up engine heated water for the exchanger?
    May 2015
    Oregon
    128
    Default Re: Water heater -heat exchanger
    If you are unconcerned about raw sea water cooling your engine, then it's fine to use for heating water.
    You want to tap into the hottest water. Usually where your thermostat housing exits water from the engine. If you have a water cooled exhaust manifold, where the water exits could be the hotter place.
    Dec 2006
    Chaumont Bay, N.y., USA
    5,886
    Ayuh,.... There should be a 1/2" pipe plug just aft of the t-stat housin', in the intake manifold, to get the hot water from, 'n a capped nipple, or another 1/2" pipe plug in the circulatin' water pump for the return water,....
    Dec 2015
    maplevalley WA
    5,049
    You have the potential to heat the tank to engine temp so adding a mixer valve is necessary to prevent scalding with the domestic hot. Be safe!
    Dec 2015
    maplevalley WA
    5,049
  6. #6
    great post.. keep sharing ..
    Power Transformers in India | Wire Harness Manufacturer in India | Transformer Manufacturer in India
  7. #7
    Dec 2015
    maplevalley WA
    5,049
    This thread is over two years old.
  8. #8
    Dec 2006
    5,886
    pradeepkumar is a spammer,......
  1. 6-71 in line natural water heater with exchanger install
    By littleriver in forum Detroit Diesel
    Last Post: 06-17-2013, 02:14 AM
  2. water blowing out heater exchanger
    By fiaadmin92 in forum Detroit Diesel
    Last Post: 06-29-2010, 07:18 AM
  3. Drain plug at end of heat exchanger leaking water into bilge while in water
    By ruggles in forum Mercruiser Sterndrive Archive
    Last Post: 08-16-2008, 11:50 AM
  4. Heat exchanger water heater ports on a 6V92
    By Drew Harris in forum Detroit Diesel
    Last Post: 08-11-2008, 10:46 PM
  5. Water leaving my heat exchanger
    By coryneil in forum Mercruiser Sterndrive Archive
    Last Post: 02-22-2008, 11:52 PM
