how to re-install shift linkage on 60hp Johnson J60TLCDS ?
dmik
I just replaced the water pump impeller and having great difficulty re-connecting linkage at the top. any suggestions? thanks ! David
It's a 3 cyl. VRO model.
Shift rod must be offset to port side. If it isn't you can turn the shift rod under the cowling with nose pliers. If the rod has been rotated a full turn or more its hight is misadjusted. Gear should be in neutral.
Now push the shift lever on starboard all way in and rotate the lever a little back or forth, then release it. You should find the connection position soon. It may help to disconnect the horizontal shift link on the starboard side.
