pafisherman
OK I bought this boat in late March. Wanted to make sure the water pump was working correctly. Put it in a tub of water and ran it and could see I needed a new impeller so I changed that. when the ice opened up on lake in early April I took it out for a test run and it ran good for about 15 minutes then spit and sputter then shut down. priming ball was hard and not start again unless I left it set for awhile. So I brought it back and pulled the carb off and cleaned it out then cleaned fuel filter screen Didn't see anything bad in there so I figured I would try it again. This time with new plugs and a new fuel line and priming ball. Same thing happened. It will run wide open or just idle for trolling but will shut down and I have to wait for awhile for it to run. Now the water is pumping fine and doesn't seem to be getting hot but it seems to be shutting down after it gets warmed up. The model number is E15RL4EEB . Not sure what I should try next.
