Snakeriversailor77
Looking to find some thoughts on a direction to initially go with a Evinrude 175 2 stroke which is not firing on the 2 bottom cylinder of the port bank of the V? Swapped out the powerpack/ignition box from the other motor and still have the same problem. Same two cylinders not firing. Tends to indicate another issue than the ignition box. Im going to check the stator for output next. It doesn't seem that two cylinders on the same side would not be firing if a single component went bad as they are usually paired to the opposite side cylinder not the same side. Any thoughts or direction to head.
