lightfoot1
Got my dad’s ‘67 Merc 9.8 hp working again, but when I run it in a garbage can I get an awful lot of ugly grey/tan oil floating on top, is that normal for these old engines?
Think of the gazillion gallons of oil that flowed into rivers, lakes and streams over the years from two strokes...
Jeff
Where is the oil coming from?
Well, millions of years ago there were Dinosaurs and plants that died and got covered in muck
Ok, you mean more recently.
This is a 2 stroke so the gas it burns is mixed with oil (typically at 50 parts gas to 1 part oil). The oil is "designed" to burn up completely if the motor is running at it's operating temperature AND it's perfectly tuned running at ideal atmospheric conditions.
Almost none of those (variables) all come into line at any given time, so after combustion you end up with burnt and un-burnt oil being forced out of the exhaust with other exhaust gasses/chemicals.
Their "path out" of the engine is down the exhaust housing (leg) and out through the prop (on thru prop exhaust models) or out the little port just above the prop (on earlier designs).
The inside of the exhaust housing also get "coated" in all that gunk so whatever doesn't (immediately) make it out of the exhaust slowly slithers it's way down (when the motor is sitting) and drips out.
Usually whatever doesn't end up in the lake will drip out on the road on the drive home from the launch to your driveway, but when you run it at home and then shut her down, the evidence will end up on the garage floor or the driveway (often alarming the owners who are not used to seeing it).
