73 302/5.0l mercruiser
ok folks. im james its my first time to post here as I just became a member. yesterday I had taken my 1973 caravelle trihull out to the lake. It ran like a champ for about 45 min then I noticed a change on my vac. guage. I was loosing vac. off the intake. and then the engine wouldn't run over 2000 rpm. after getting closer to the dock I had shut the engine off to coast in as there was others putting and taking boats out. after dock cleared I couldn't get engine to fire up even in "neutral" so I had to jump I and swim to bank and pull the boat in. is there anything to have a look at other than fuel filter?
1..... then I noticed a change on my vac. guage. I was loosing vac. off the intake.
2..... and then the engine wouldn't run over 2000 rpm.
You'll do much better if you'll post your questions in the Mercruiser forum.
1..... a vacuum gauge on a Marine Engine is rather useless. When under load (and a Marine Engine is typically under load when above hull speed), manifold pressure drops substantially. This is because the throttle plates are well open enough to meet the engine's fuel/air demands for heavy loads. On a car/truck the dynamics are quite different.
2.... have you looked at your ignition's progressive advance and total advance?
