ipokesnails
I recently acquired a free 1974 21' Reinell cabin cruiser with a marinized 1971 Ford 351w.
The boat had been sitting on land for 8 years without being touched.. After an oil change, some WD-40 in each cylinder, and a replacement starter, it fired up just fine.
Now it sometimes seems quite difficult to crank..
In this video it seemed to turn just fine at first and nearly start, but then it cranks weakly.
The starter can turn the engine much faster than that, but the battery was getting weak. When it gets like this, even hooking jumper cables to the starter doesn't make a difference.
The engine was even very difficult to crank by hand. Immediately after this video I removed 3 spark plugs to try again; the engine cranked perfectly and started (oops, forgot the unplug the coil)
I put the spark plugs back in, the engine started and ran just fine.
So what might be causing this? The replacement starter is from a junkyard, but it's certainly strong enough to crank at normal speeds and start the engine. It seems restricted, but removing the spark plugs lets it crank fine. It then cranks properly when the plugs are back in.
