Results 1 to 15 of 15
  1. #1
    Join Date
    May 2011
    Location
    Fort Jones, Ca.
    Posts
    105
    Default Tires wearing bad
    A friend of mine bought a new boat and trailer. Trailer has two axles and the tires on the back axles wore out in 3000 miles. Fronts are fine. What would cause this?
  2. #2
    Join Date
    Sep 2006
    Location
    Baton rouge, La, USA
    Posts
    2,501
    Default Re: Tires wearing bad
    did the tires scallop?or wear smoothly?i think the boat is setting too far back on the trailer...i added trim tabs on a boat and moved the boat back so the tabs would not come up on the trailer runners and the tires scalloped badly in 500 miles...
  3. #3
    Join Date
    Sep 2006
    Location
    Posts
    2,501
    there is a formula somewhere for the percentage of total weight vs the tongue weight...the dealer should know this as he is probably the one responsible for the problem...
  4. #4
    Join Date
    May 2011
    Location
    Fort Jones, Ca.
    Posts
    105
    From what he said, it sets a little low at the tongue. Driving four hours on winding roads may be raking the rears to wear like that??
  5. #5
    Join Date
    May 2011
    Location
    Fort Jones, Ca.
    Posts
    105
    Quote Originally Posted by papyson View Post
    Sorry, I missed this one. They were worn smoothly. When he dropped it off at the tire shop today, the tire guys said that the rear tires were hot.
  6. #6
    Join Date
    May 2011
    Location
    Fort Jones, Ca.
    Posts
    105
    I'll pass that along. Thanks you guys!!!
  7. #7
    Join Date
    Sep 2008
    Location
    Hague, Virginia, USA
    Posts
    4,690
    The tongue weight should be no more than 10% of the total weight of the boat and trailer combined. Most dealers recommend 6% to 8%.
    Also, have a tire shop check axel alignment. If you look at how the axels are attached to the trailer frame, you can see how easy it is for them to get out of alignment.
    CHawk 25 DLX
  8. #8
    Join Date
    May 2011
    Location
    Fort Jones, Ca.
    Posts
    105
    I'll add that to the list of things to check. Thanks!!
  9. #9
    Join Date
    Mar 2007
    Location
    Miami Lakes, Fl, USA
    Posts
    113
    Aliment of the axels is crucial on tandem trailers. or the ties will wear off quickly
  10. #10
    Join Date
    Dec 2015
    Location
    maplevalley WA
    Posts
    5,049
    The trailer needs to be level to the ground as possible also.
  11. #11
    Join Date
    Apr 2016
    Location
    barnegat NJ
    Posts
    3,143
    Maybe a dumb question, Is trailer rated for the weight of your yacht? Wev'e all seen dumber things done!
  12. #12
    Join Date
    Apr 2016
    Location
    BAMA Country
    Posts
    250
    Quote Originally Posted by chawk_man View Post
    hopefully it's OK to bump old thread.
    my question if the rear axle is 1/4" shorther than the front (but still rolls balanced) will cause abnormal tire wear?TB
  13. #13
    I've been in that situation before, and what helped me is essential toolkit. Well, of course, first of all I've inspected every inch of my trailer, but after it - all I needed is a simple essential toolkit, like one called Apex Tool Group (can find over here: https://cozyhousetoday.com/best-tap-die-set-review/), and these tools from Apex toolkit made everything I couldn't do with my old tools before.
  14. #14
    I heard a lot of stories about it, and yes it will cause abnormal tire wear.
  15. #15
    Join Date
    Apr 2016
    Location
    BAMA Country
    Posts
    250
    dam I had to cut 1/4" off the rear axle for the new spindel install if you look closely the shorter axle can be sean.
    edit: only one side is a 1/4" shorther. I'll keep a close on on tire wear.
    I have a new replacement axle however I'm reluctant to swap since dexter the manufactor desided to ignore my spec sheet you know the sheet w/ all the details like lenght ect. ect. spring mounts where left off and the folks that sold it to me insisted on welding new mounts. they sanded off the galvanized metal welded a tad then spray painted w/ primer.
    basically dexter fouled up. I disputed the credit card payment and wasted hours of my time explaining over and over, it got to the point I said you are recording the conversation please hit the replay button, hell even a 5 year old could understand the galzination process but I got boned by the credit card co.
    I really need to go back and talk to the owner of the trailer shop where I got boned infront of the potenional customers.
    the salesman acts like he did me a favor selling a boat axle they mainly sell none boat trailer stuff. it also took them 3 months to get the axle from dexter.
Similar Threads
  1. alpha I bell housing wearing at gimbal ring
    By cloud nine in forum Mercruiser Sterndrive Forum
    Last Post: 09-25-2013, 07:33 PM
  2. Bias tires
    By materman in forum Miscellaneous marine engine topics
    Last Post: 10-19-2009, 02:13 PM
  3. HELP Need to replace trailer tires
    By glenn_w in forum OMC Sterndrive and Inboard Archive
    Last Post: 05-05-2008, 11:58 AM
  4. Trailer tires dry rot
    By dave_kirk in forum Archive 2003-2007
    Last Post: 10-24-2007, 08:20 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
