you have a yamaha built engine which probably is a copy of one of their older models...i am not familiar with them and have no idea which year and model your motor is a copy of...
i sent a message to someone who may can help you and asked him to look at this thread..
I believe your outboard has a standard Mercury electrical system, and has a 832075A21 stator that was used by Merc on most outboards from 30-125 hp. Use this link to CDIs' troubleshhoting guide- the resistance values for your stator should be on page 77.
http://issuu.com/cdielectronics/docs/practical_ouboard_ignition_troubles
There is a video on YouTube titled "How to test a coil in an antique outboard engine" by Doug Penn. I watched it several times and then bought a multimeter at Menards that has a X1K setting for ohms. You place one probe anywhere on a grounded surface and the other probe inside the spark plug wire socket and the needle should drop from infinity down to 1 to 10 ohms. One note, one of my coils read 18 ohms, and the other read 10 so i assumed one of them might need to be replaced. (my motor is a 1967 Merc 9.8 hp). Anyway I ordered 2 new coils since they were 47 years old. When they arrived I checked them both with the multimeter and got 10 ohms on each coil. The coil that read 18 ohms was probably fine, but I'm not an electrician. Basically this is just checking for decent continuity.
Hiya
Here a pic of the coil that I have View attachment 11228
Although having the resistance spec the coil is one check, you will also want to check the peak voltage it is producing and to do this you will need either a multimeter with a built in DVA or a separate adapter. Buying an adapter can be quite pricey but fortunately they are very easy to make. Here is a video of me making mine: https://youtu.be/juhri_NxQcQ
I'll be doing a video very soon on using it to perform the exact test you are talking about.
Stuart
Thats great thanks - will get the DVA built and look forward to the diagnostic video
Cheers
Wayne
