chrysler 75 hp outboard. starts goes in to gear but not power
boater85
I have a older chrysler out board 75hp. Starts great, goes in to gear. Then you give it gas and it's as if the engines still in neutral. But does move slightly. Ideals normally but and goes in gear but propeller doesn't spin. Any Ideas.
Welcome!!
The year, serial# and model should be in the post somewhere.
Possible the props hub is spun??
Remove the prop, mark the rubber hub and reinstall.
Go for a spin and see if the line moves.
