I have a Honda 8HP remote outboard on a 27 foot sailboat. I backed out of my slip today and when I moved the lever forward and powered up the motor went in reverse. I place it in neutral and the prop stops spinning. I bring the lever back it goes in reverse. I pass through neutral and into forward again it goes into reverse. no matter what i do I only have neutral and reverse. After a hair-raising maneuver I was able to dock in an empty slip. I removed the top and observed the cable push and pull in the correct directions. So it must be something going on in the gearbox. Any ideas or suggestions would be appreciated. tnx ted
