Results 1 to 2 of 2
  1. #1
    Default water pump problems
    I have an 86 60 Hp. Johnson and I replaced the water pump. Since I have reinstalled my lower unit and made sure my tube was inside the water pump it will not pump water up through the motor. I have made sure the tube was not blocked by blowing air up through the tube and it came out the little hose fine. What could be the problem really aggravated in Ky.
  2. #2
    Join Date
    Aug 2018
    Location
    Milwaukee WI
    Posts
    18
    Default Re: water pump problems
    Is the water level above the water pump? The water pump needs to be submerged in order to draw water up.
Similar Threads
  1. water pump problems
    By humpty in forum Johnson Evinrude Outboard Forum
    Last Post: 05-24-2010, 10:52 PM
  2. 98 water pump problems
    By tvhj in forum Mercury Mariner Outboard Archive
    Last Post: 09-07-2008, 03:22 PM
  3. Water pump problems
    By crappie_man in forum Johnson Evinrude Outboard Archive
    Last Post: 11-13-2007, 10:57 PM
  4. Water pump problems
    By dustin Gross in forum Mercury Mariner Outboard Archive
    Last Post: 09-25-2006, 09:27 AM
  5. Water pump replacement problems help
    By Tcopello in forum Archive 2003-2009
    Last Post: 03-08-2004, 10:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
