Put the boat in the water today (opening day of boating season here in Seattle.) Should note that it had about 1/2 a tank (5 gallons) of 2 year old gas so I topped it off with 5 gallons of new gas and fuel system cleaner. After a few priming lever pumps, hit the starter and it basically fired right up. warmed up and moved away from dock, but as soon as I hit it to get on plane I get maybe 2 seconds of full power then it falls on its face. if I idle for 30 seconds, it will repeat the 2 seconds of full power. New primary filter and plugs. Also, removed air silencer and noticed the emergency fuel enrichment lever was in 'on' position. moved it to the 'normal' position and it will barely run. Restricted fuel? Ideas on where to look?
