Results 1 to 2 of 2
  1. #1
    Default What plug/recpt to use ?
    Changed out to 6 Ga.wiring for my TM. Now what plug/ recpt do i use for 6 ga. ?
    Thanks for any help.
  2. #2
    Join Date
    Sep 2006
    Location
    Baton rouge, La, USA
    Posts
    2,501
    Default Re: What plug/recpt to use ?
    same one you had if the wire will fit into it....if not then you will have to upgrade to bigger size...not enough info given to help you more...
Similar Threads
  1. Replies: 1
    Last Post: 06-16-2010, 10:37 PM
  2. Another B21 Block question Oil plug or water plug
    By followingsea in forum Volvo Penta Gas Archive
    Last Post: 04-05-2008, 01:10 AM
  3. Spark plug gap and plug type 2004 mercruiser 30
    By rhop0410 in forum Mercruiser Sterndrive Archive
    Last Post: 05-07-2007, 12:02 PM
  4. 1986 30L OMC Point amp Plug Settings firing order for plug wires
    By optimizer in forum OMC Sterndrive and Inboard Archive
    Last Post: 06-29-2006, 01:11 PM
  5. Points Gapping Spark Plug Gapping amp Alternate plug wires
    Last Post: 06-26-2006, 02:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
