Results 1 to 5 of 5
  1. #1
    Default 1990 Yamaha Stern Drive Tilt Trim Hose removal Help!
    Hi All -- I bought a boat last night. I came home from work today and the prop was down to the ground. Tilt Trim fluid had leaked out of a pin hole all over the ground. I have the arms off and have the hose off the arm, but I can't get my wrench in to loosen the bolts where they connect near the transom. Do I have to take the whole outdrive off etc.? Or is there a special tool for this?
    And, does anyone know a cheaper option for replacing the hose than $174 from Yamaha? Its like a 1 ft. hydraulic hose! I didn't know until today that Yamaha sterndrives were so rare.
    Thank,
    Josh
  2. #2
    Join Date
    Dec 2006
    Location
    Chaumont Bay, N.y., USA
    Posts
    5,286
    Default Re: 1990 Yamaha Stern Drive Tilt Trim Hose removal Help!
    Quote Originally Posted by holy1above View Post
    Thank,
    Josh
    Ayuh,.... The Yamahas are a pretty raw deal in North America,.... I hear they're popular else where on the planet,....
    My Guess is, the lines can be replicated at a Hyd. Shop, I believe they're 1/8",...
    Maybe a Merc line will fit, Donno, only seen a couple, from afar,...
    Capt. Ken, from down Florida way is sorta the "Go to Guy" for Yamaha drives,....
    He stops by iboats on occasion,... ain't seen him in here for awhile,...
  3. #3
    Did you get the hoses that you need? We went to take our boat out this past weekend, and when we went to the storage yard, the foot was resting on the pavement. Got it up and home, now looking for options for the replacement hoses. I'll likely take them to a hose shop and see if they can replace the rubber or make all new ones. The OEM ones that I'm finiding online are over $150 each. I'd like to replace all of them, but not for $600!
    x2 on Capt Ken. He's the go-to gut for these stern drives.
    There's also a Google group with some common DIY suggestions:
    https://groups.google.com/forum/#!fo...ha-sterndrives
  4. #4
    Yes. Find a NAPA auto parts store. They made one for $22. But not every one of them does it.QUOTE=MerryO;516265]Did you get the hoses that you need? We went to take our boat out this past weekend, and when we went to the storage yard, the foot was resting on the pavement. Got it up and home, now looking for options for the replacement hoses. I'll likely take them to a hose shop and see if they can replace the rubber or make all new ones. The OEM ones that I'm finiding online are over $150 each. I'd like to replace all of them, but not for $600!x2 on Capt Ken. He's the go-to gut for these stern drives.There's also a Google group with some common DIY suggestions:https://groups.google.com/forum/#!fo...ha-sterndrives[/QUOTE]
  5. #5
    $22 from NAPA sounds like a great deal! Mine are likely original to the boat, and one blew out just above the fitting. They were a pain to get off, but I got all four off and taken to a hydraulic hose store nearby. They are charging me $52 each to replace the hoses. I know these will be high quality super flex hose. The one that blew was the inner starboard hose, so I had to take off the outer hose to get to it. Since I had to take off two, I figured that I should replace all four. My expense will still only be slightly more than one OEM hose at retail.
    Did you find a wrench that worked for you? I ended up "making" a couple wrenches. The most useful one was an offset 10mm 12-point that I cut to fit around the tubing. I'll post pics of those as well for others.
Similar Threads
  1. Stern drive paint removal
    By mtrigger in forum Volvo Penta Gas Engine Forum
    Last Post: 11-15-2011, 12:03 PM
  2. Removal of OMC 1979 Series 800 Lower Stern Drive
    By jmayfield in forum OMC Sterndrive and Inboard Archive
    Last Post: 03-10-2009, 09:42 AM
  3. 1976 OMC Lower Stern Drive removal
    By Sherry Stahr in forum OMC Sterndrive and Inboard Archive
    Last Post: 09-17-2008, 03:06 PM
  4. Stern drive removal amp trim hoses removal
    By david_ray in forum Mercruiser Sterndrive Archive
    Last Post: 03-27-2008, 05:53 PM
  5. Volvo penta stern drive removal problems
    By edward gibson in forum Volvo Penta Gas Archive
    Last Post: 05-30-2006, 04:19 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
