Dirtmerchant
I bought a pontoon with a rough running 2001 2 stroke 70 hp motor on it for a decent price assuming that it would be a quick fix. It idles alright and runs low speeds alright with a subtle miss. WOT it only runs at 4k rpm. I pulled the spark plugs. The bottom plug was wet. Replaced all 3 plugs. Ran the same and same plug was wet. Spark tested it and it sparked fine. Swapped coil pack with cylinder 2 and cinder 3 was still the problem. Did a compression test and all compression was even. Timing test showed that timing was off by about 1 tooth on all cylinders at idle speed? Is that a possible problem or is it just off because of the miss? Also pulled the fuel pump and squeezed primer bulb. Fuel didn't appear to leak through the membrane. I really don't want to pull the carb and clean it because I have never done a link and sync. I have disassembled plenty of carbs though. But I am nearly at the end of my knowledge on this type of problem. (Also pulled the inline filter and there was no water and a couple of very very small black specks. Any ideas or anyone else with this problem? Am I missing something????
