Results 1 to 3 of 3
  1. #1
    Default Antique Evinrude, Fuel/Oil Mix Ratio
    Have antique Evinrude, probably 1925 to 1935. Need to know correct fuel mix. Once had a 1956 30hp Evinrde and it used 25:1 gas/oil mix. I suspect the old motor needs even more oil.
  2. #2
    Default Re: Antique Evinrude, Fuel/Oil Mix Ratio
    In checking the numbers I found out the motor is a 1939 3hp Evinrude. I decided to use 16:1 gas/oil mix. After cleaning out the carb, tank, etc., and much raping the rope and pulling it started and runs good. Also replaced the condenser and sparkplugs. Not bad for a 76 year old motor. The water pump seems to be very weak. The impeller is metal instead of rubber. Probably don't need to run for long periods.
  3. #3
    This is not quite a fuel/oil mix question. I purchased a 1961 Sea King 5HP outboard. I have no manuals with it. I want to change the gear oil. Is there a recommendation of a type of oil given that it is a vintage motor?
Similar Threads
  1. 1965 Evinrude 60 HP V4 Fuel/Oil Mix Ratio
    By duffer1960 in forum Fuel / Oil Mixture Ratio
    Last Post: 08-26-2013, 01:54 PM
  2. Fuel Ratio Evinrude
    By ksfish in forum Johnson Evinrude Outboard Archive
    Last Post: 03-15-2009, 11:46 AM
  3. Fuel oil ratio 1973 evinrude 6hp
    By huronpete in forum Johnson Evinrude Outboard Archive
    Last Post: 08-05-2008, 08:23 PM
  4. Old evinrude fuel ratio
    By Bobjhs in forum Johnson Evinrude Outboard Archive
    Last Post: 07-26-2006, 06:43 PM
  5. 1978 Evinrude 35 HP outboard Fuel ratio
    By duane in forum Johnson Evinrude Outboard Archive
    Last Post: 05-07-2003, 11:08 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
