I bought a 1992 2 Stroke 8HP Johnson outboard the other day. It is a standard shaft rope start. The owner said it ran fine and it had been sitting in the garage for a couple years. We got some new fuel in the remote tank and it initially wouldn't start after the first 10 pulls or so because he didn't have the choke pulled out. After choking it the thing fired up after about 4 more pulls and revved up like you would expect but we only ran it for a few seconds because we only had a 5 gallon bucket and it wasn't deep enough to cover an additional small water intake that is above the cavitation plate and didn't want to chance it not drawing enough water. Satisfied with it running I took it home with me.
I built a stand for it and got in a clean trash can for a test tank and was going to give it a full once over and make sure it was pumping water and cooling properly and such before taking it out. The problem is I cannot for the life of me get it to show any signs of life even after troubleshooting it to death (short of breaking down the parts). I put new plugs in it, verified I'm getting a spark on them. The spark might not be as vigorous as I'd like, but that is probably due to me not being able to pull the rope very fast while leaning over looking for the spark. But it should be plenty to ignite fuel.
I've tried starting fluid through the carb, as well as in the cylinders with varying amounts, and not even the slightest indication of ignition. I've tried starting with throttle full, idle and everywhere in between. Choke on, off and in between. At this point my arms are shot and I'm not sure what to try next. This is not my first 2 stroke, but first outboard. I almost always find that even when something is wrong I can get a motor to at least sputter a little by placing some fuel or ether in the cylinder, and since it started yesterday without nearly the effort I've put in I'm thinking maybe I'm doing something wrong, or something got clogged in the carb between yesterday and today.
I would have to say the fuel delivery to the carb is not the problem, as there is a little fuel dripping from the carb after I prime the bulb. I don't know if that is normal though. The tank is vented (cap is just resting and not screwed in just to be sure). The original plugs were pretty oilly, but after since changing the plugs they seem to stay pretty dry despite all the starting I'm trying to do.
Anyone have any tips on how to get a general diagnosis on where the problem lies?
Thanks a lot of any suggestions you can offer.
