my trolling motor is doing the strangest thing. in the "stowed" position and in the "momentary" position on the switch it works through all speeds perfectly. soon as I unhook it and lower it in the water it will only operate on one speed in the momentary position, if I move the switch to the "rabbit" position in which you step on the pedal and it is in rabbit only it works perfectly ......... pull it back to stowed position and in momentary position and it works like I should again
weird huh!
any ideas????
