Hey guys got a little issue here with my 1982 50horse outboard. Few month ago I redid de carbs and changed the gas tank on it. It work great out side the water and the day I took it fishing it started no problem got out of the harbor no problem(20min at 5mph) then I speed up to go to the grounds I got there but when I troutle down to check the fish finder it didnt want to stay at low rpm and it would die. It was a strugle to get it to turn on again and when it would turn on its idle would be off and it would die when put in gear untill I tricked to hit high rpm with the choke once it was at high rpm it would run great like nothing happened. Then when I got to the harbor it would only go at 4mph if I opened it more it would die. So at home I did the carbs again thinking I might have done them wrong even following the parts schematic. And there it was started like a charm at home same thing out the harbor and to the grounds but it did it to me again. Though this time it was harder to get it to start and it wouldn't idle. I got it to turn on by priming the carbs passed full while cranking and I would only stay alive if I kept applying choke on and off on my way back so yeah it was fun..... I check the compressions and they're all very very close to 120 so the heads are fine. Can any one help me out here??
I'm thinking redo cards and go back to old gas thank??
